New wheels (for me at least)
FtLaudBlkGT
I've been eyeballing Raptor wheels for quite some time and came across this smoking deal for the beadlock raptor wheels and 35's for $800
Only problem is that the center cap will not fit on the rear wheels because of the irs shaft but I think a 5/16 spacer might do the trick.
Truck has a 2.5" lift front and 2.0" rear and no rubbing issues as of yet.
IRS shaft sticking out the back.
FtLaudBlkGT
FtLaudBlkGT
Would it hurt to cut off the end a bit?
I could trim off some of the non-threaded area as long as I don't cut into the threads I would be fine. I am adding a 1/4" spacer and seeing what would need trimming from that point.
69Hcode
Albuquerque
Just a thought. Could you pull the shaft and put a spacer on the backside of the hub? The extra distance might be good with the lift. And your wheels won't stick out further than the front and look weird.
diablood5
ga
still a work in progress
