Done!
Mirrors are installed.
Steps taken:
1. Unpack and inspect for damage.
2. Remove door panel - youtube helps, some say to take the door handle off, but it isn't necessary.
3. Unplug old mirror and compare new connector and old connector. We matched!
4. Plug new mirror in and check for proper operation. GOOD!
5. !!! Tie a fish line to old mirror wiring !!! Tie something big to the other end of the fish line to keep it from pulling all the way thru.
6. WITH WINDOW ROLLED DOWN, Loosen all three mirror nuts. Put a piece of electrical tape across the top of your socket, and press it onto a a nut. This will help insure the nut does NOT get dropped down into the door. Remove the lower nuts first. WHILE HOLDING THE OLD MIRROR, Remove the top nut.
7. Remove new nuts from new mirror. The flange washer on the new nuts was much smaller than on the old ones, so I reused the old nuts.
Old nut on left.
8. Untie fish line from OLD mirror and tie it to the NEW mirror connector.
9. Start the new mirror wiring thru the door.
10. Install the new mirror loosely. There is a small clip near the top of the mounting surface that has to go in first. After this clip is in the hole, and the studs are through the mirror will hang on its own.
11. Start the top nut. Remember the tape on the socket to prevent nut loss.
12. Pull the wiring harness completely thru and connect. Now is a good time to double-check correct operation.
13. Start the lower nuts, then sort of snuggle everything up a tiny bit and check for fit. If AllGood, tighten everything to plenty snug, but not quite GUTENTITE. You are dealing with a plastic housing. I rechecked operation one more time.
14. Reinstall the door panel.
Side by side comparison
After install comparison
Extended comparison
I cannot verify that the mirror heaters actually work, but I did verify that there ARE electrical connections to the mirror glass itsself, so I "assume" the heat will work.
