Go Back   Ford Expedition Forum > Ford Expedition Forum > Transmission & Drive train
Register to remove these ads.
awd tcase noise, 4wd sticks
This is a discussion on awd tcase noise, 4wd sticks within the Transmission & Drive train forums, part of the Ford Expedition Forum category!
i was getting this grinding noise at different speeds and rpms. mostly while accelerating but occasionaly while slowing down. the ...
Reply
Old 08-29-2007, 07:25 AM   #1 (permalink)
Default awd tcase noise, 4wd sticks
i was getting this grinding noise at different speeds and rpms. mostly while accelerating but occasionaly while slowing down. the fluid was black and watery, so i changed it and the noise got better. but wheni put it into 4wdhi it gets reall really bad. sounds like the entire driveline is dry. and it doesnt kick out when i swtich back to awd. until i back up a few feet
i was told it could be the tcase pump and the gears inside. i really hope not. any ideas?
ROCKSBITE is offline   Reply With Quote
Old 08-29-2007, 05:55 PM   #2 (permalink)
Default
Transfer cases are expensive fyi. Even used. If you wanted to try you could cut the lead to the clutch on in the transfer case. Although its more likely the mechanical engagement thats problemed by what you said the transfer case is damn expensive you could try it beforehand. Or you could try and just pull the connector and see what happens.
__________________
2004 Ford Excursion Limited 6.0 PSD
-SCT Livewire w/ Innovative diesel tunes
-Viper 5900 remote start/security
-Banks monster exhaust
-Recon smoked mirror signals
-Airraid drop in filter
-Predator II strobes red-red
-zoodad
-Soon headstuds and EGR delete
1999 Ford Expedition XLT 4.6L 2V *Sold*
-K&N FIPK cold air intake
-Gibson Headers
-Gibson Catback exhaust
-Superchips tune
-Airlift rear leveling
-Chrome grill guard
-LED tail lights
-Chrome billet grille
AvroAero is offline   Reply With Quote
Old 09-04-2007, 10:43 AM   #3 (permalink)
Default
ok i pulled the fuse for the 4x4 system and i have no noises at all.
if i read right the awd is a clutch that engages to speed up the front wheels. the 4x4 is a mechanical motor on the side of the tcase. if i have a minor noise in awd and a major noise in 4wd hi. how do i test it? is there a way to maually put it in to 4wd hi with out the motor? if the shift motor cant ir isnt putting it in to gear all the way i could see it making this noise
Old 09-20-2007, 03:56 PM   #4 (permalink)
Default
i took it to a trans shop and he said teh noise is because of the front tires being a different kind and the they were worn differently so they will measure different
Old 09-20-2007, 09:48 PM   #5 (permalink)
Default
Yea, the A4WD doesn't like different tire sizes. The computer thinks these always a diference in axle speeds. I cut my A4WD system out to get rid of any problems, I like 2WD better anyways.
__________________
-zoodad
-Gibson Headers
-Superchips tune
-Chrome grill guard
-LED tail lights
Old 09-26-2007, 02:01 PM   #6 (permalink)
Default
yeah i get much better mpg with 2wd. but winter is coming. with different tires would it still do it in 4wd and in gravel?
Old 09-26-2007, 04:28 PM   #7 (permalink)
Default
Which fuse did you pull? The one that cuts the a4wd and 4wd out? Fuse 104 in the battery junction box, pull that. Then find fuse 23 under the dash, pull that also. Those feed the a4wd. Fuse 23 may kill a few things including overhead console, heated seats, and rear AC. Although it is possible that that module could get power from another module (looking at the diagram). If you want a bullet proof method cut the brown wire on the harness on your transfer case. The one that strays alone. You can always splice it back together. Tape it up.
Try seeing if it still does it, if it doesn't then your a4wd is messing up somewhere (maybe constantly trying to engage). Do you get any jerking when you drive? If it doesn't stop anything, then your more likely to be in the area of a screwed transfer case or motor. If so maybe check the motor and see whats its getting for power. Compare the readings with it in 2wd, a4wd, 4hi, and 4low if you can get there. Maybe one of the shift relays is welded, or a module is fuxed.
__________________
-zoodad
-Gibson Headers
-Superchips tune
-Chrome grill guard
-LED tail lights
Old 11-10-2007, 06:55 PM   #8 (permalink)
Default
new tires fixed all my problems
:troll:
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
