Go Back   Ford Expedition Forum > Ford Expedition Forum > Transmission & Drive train
Register to remove these ads.
Brown Wire Mod
This is a discussion on Brown Wire Mod within the Transmission & Drive train forums, part of the Ford Expedition Forum category!
So i was researching into disengaging the A4WD, and ran across this site. http://www.explorer4x4.com/controltrac_mod.htm Its aimed towards explorers and I ...
Like Tree1Likes
Reply
Old 05-16-2008, 06:32 PM   #1 (permalink)
Registered User
Default Brown Wire Mod
So i was researching into disengaging the A4WD, and ran across this site. http://www.explorer4x4.com/controltrac_mod.htm Its aimed towards explorers and I was curious if anyone knew if it would work for an expo, I imagine it would.
__________________
2001 Expo - 5.4, K&N intake, Gibson catback with Flowmaster 40 series, Pioneer deck, two Infinity 12's w/ 700 watt amp, 22" chromes on 305/40/22 Kumhos, Edge programmer... what's next?
mgtsldr38 is offline   Reply With Quote
Old 05-17-2008, 06:34 AM   #2 (permalink)
Default
It would be really nice to know if i can take my truck out of a4wd. This would help save on gas a little :)
__________________
4x4Dude is offline   Reply With Quote
Old 05-17-2008, 11:12 AM   #3 (permalink)
Default
When I first signed up on this site, I remember someone posting a thread about cutting into the wires for the A4WD system to get it to disengage. But from reading that link, the author says that it won't add any added mpg just let's you decide rather than a computer to use only 2 wheels instead of all 4. But cool idea.
MaverikDS is offline   Reply With Quote
Old 05-17-2008, 05:56 PM   #4 (permalink)
Registered User
Default
I wanted to do it because its annoying turning the wheel at loc and it acting like its in 4wd, and also it might be a little more fun at the stop lights, haha.
__________________
Old 05-17-2008, 10:24 PM   #5 (permalink)
Default
Def. I understand the want, just was saying I didn't know if it was worth the time to invest simply for the MPG gain.
Old 05-18-2008, 06:47 PM   #6 (permalink)
Registered User
Default
Guys it does work but please look at the wiring diagram. The brown wire is to me really kindamof light brown. If you go by the wiring diagram you can use process of elimination. There are only five or so wires so it is easy to identify the last wire. I cut the wrong one first, then I cut the right one. When I knew it was right I taped it up so no moisture would effect it. MPG change???? Not enough to notice. The sluggishness that you feal when you acclerate is gone. Now you can power brake if that would be what you are looking to do. In my case the lifted Expeditions experience vibrations which lead to transfer case failures. That is why I wanted to eliminate the 4AWD. Now it drives alot smoother, even when you are turning in the parking lot, no more front end drag. I like it and in my climate I will never use the 4AWD. The job was easy and BIG thanks to the forum for giving a good wiring diagram.
__________________
2007 Expedition
EXPOX4 is offline   Reply With Quote
Old 05-28-2008, 08:42 PM   #7 (permalink)
Default
It can be done. You just need to trace the wire from the transfer case and switch it. Or if you can't trace it run 2 wires to the transfer case and tap in down there. There is a brown wire the strays alone on the transfer case thats the magnetic clutch wire.
__________________
2004 Ford Excursion Limited 6.0 PSD
-SCT Livewire w/ Innovative diesel tunes
-Viper 5900 remote start/security
-Banks monster exhaust
-Recon smoked mirror signals
-Airraid drop in filter
-Predator II strobes red-red
-zoodad
-Soon headstuds and EGR delete
1999 Ford Expedition XLT 4.6L 2V *Sold*
-K&N FIPK cold air intake
-Gibson Headers
-Gibson Catback exhaust
-Superchips tune
-Airlift rear leveling
-Chrome grill guard
-LED tail lights
-Chrome billet grille
AvroAero is offline   Reply With Quote
Old 08-19-2008, 04:24 PM   #8 (permalink)
Registered User
Default
So if I just cut the wire I will only have 2wd and not be able to use 4wd hi or low?
If I put a switch in line with the brown wire what do I have to do to get in 4wd hi?
Thanks
Pete
__________________
1999 EB 5.4 A4WD
jmnt593 is offline   Reply With Quote
Old 08-19-2008, 08:16 PM   #9 (permalink)
Default
If you cut the brown wire you'll permanetly disable A4WD. 2Hi, 4Hi, 4Low will all be active. A4WD uses a magnetic clutch to engage the front driveshaft where 4x4 uses mechanical means.
If you put a switch inline with the brown wire, you don't need to do anything but turn your dial to 4Hi to get into 4hi. Because its two different systems the brown wire only affects the A4WD aspect. They do it because some vehicles don't have the 2hi option on the dial.
__________________
-zoodad
-Gibson Headers
-Superchips tune
-Chrome grill guard
-LED tail lights
Old 07-12-2010, 08:45 PM   #10 (permalink)
Default
so to rehash this topic since i am thinkin of doing this to my expy, i can cut the brown wire and my truck will be in 2wd but my selector switch will still work for 4h and 4l? just checkin cuz in the explorer forums, they say you will still be in awd...im not lookin for mpg. i didnt buy a full size suv and lift it for mpg. i just dont like awd. i enjoy running in 2wd sometimes when im offroading...makes it harder and you get better rooster tails!
__________________
01 EB. 4" Rancho Lift. 35" Nitto AT on 18x9 KMC. Warn hidden winch mount with XRC8000 winch.
nvycrmn is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
