Diesel Conversion ??
Invictus
Indiana
Would it be feasible to convert a 1999 Expedition to a Diesel Engine ?? Finding a donor would be no problem..
monsta
Big Island of Hawaii
I doubt it but then again...deep pockets can do just about anything automotive.
What engine were you thinking of swapping in?
monsta
Too heavy and a tad bit too long, I would assume.
A new front end would be in order. Not the body but the subframe and suspension.
Would a compatible tranny even fit in the hump?
I would say it would be easier to convert a Dodge QC into an SUV. Especially since in Mexico they have a Ramcharger that is based off the Ram reg cab, short bed.
Hell, even stretching one of those would be easier! :D If you could get it...
quakebuilder
SoCal High Dezert
i have been toying with this idea for a few months now and i called an engine supply company to get an idea of weights. the 4.6 weighs 400lbs, the powerstroke 7.3 weighs in at 870! for transmissions options though i would prefer a stick and then swap in a dana 60/70 rear out of a superduty to get the speed sensor. i would think that a heavier front spring will definately be required for stock applications however since we are installing suspension systems in our Trophy Truck conversions the new longer/heavier coil would most likely work.
has anyone else given this serious thought?
green03
College Station, TX
what about the 6 liter? with some good head studs they can make alot of power bone stock and hold up. i think it is a bit smaller and lighter.
Matt R
737jet
Vancouver BC, Canada
I'm probably wrong about this but I'll give it a shot. My buddy was looking to get a 1997 f250 diesel. I never saw it, just read the add.
Correct me if I'm wrong but wouldn't that front end/clip be the same as a 1997 f150? wich is the front end of an EXP?
cfarnAK
