Go Back   Ford Expedition Forum > Ford Expedition Forum > Transmission & Drive train
Register to remove these ads.
engine code p1151
This is a discussion on engine code p1151 within the Transmission & Drive train forums, part of the Ford Expedition Forum category!
i have a 2000 ford expedition 5.4 and after doing a complete tune up (plug,wire,vac hose,filters and pvc)and put headers ...
Reply
Old 05-07-2010, 03:32 PM   #1 (permalink)
Registered User
Default engine code p1151
i have a 2000 ford expedition 5.4 and after doing a complete tune up (plug,wire,vac hose,filters and pvc)and put headers and dual exhaust on. i discovered that check engine light is either blown or unplug (bought at a used car dealer).so it was running funny, ran the codes and got P1151.i was wondering if an exhaust leak at the header to the down pipe before the first o2 sensor would cause this?
I'm having a hard time getting the exhaust to seal up any info will
help thanks
jrmustang is offline   Reply With Quote
Old 05-07-2010, 05:07 PM   #2 (permalink)
tonydiv's Avatar
technical advisor
Default
This is from obd-codes.com
What does that mean?: A Heated Exhaust Oxygen (HO2S) sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Symptoms: You will likely not notice any drivability problems.
Causes: A code P1151 may mean that one or more of the following has happened:
Electrical:
Short to VPWR in the harness or HO2S
Water in the harness connector
Open/shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system:
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam Timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
__________________
1998 XLT 4x4 5.4, Rancho 4" lift w/RS9000 shocks, 3" Body Lift, 35" BFG AT KO on Weld Wheels, Tactical Armor Group Bumper, Tuff Stuff 12,500 lb winch, Rancho Skid Plate, Flares, Magnaflow SS Dual exhaust, Dual Optima Red Tops, Pioneer Touch Screen Nav Unit, Pioneer DVD w/ 7" Drop Down, Backup Camera w/ 10" Monitor SOLD 5/20/12 Replaced with a V10 Excursion Limited
tonydiv is offline   Reply With Quote
Old 05-08-2010, 05:47 PM   #3 (permalink)
Registered User
Default
it has been running rich, back firing, and hesitent in lower rpms im going to get the exhuast leak fixed this week and erease the codes. But how do i test the o2 censors to make sure they are sending the correct signal. what would be the next step that you would do?
Old 05-09-2010, 12:15 PM   #4 (permalink)
Default
I am not sure of any test that you can do on the o2 sensor. With that said, I have replaced my share of them. They fail and start to send a lean code to your computer. The computer adjustes to a richer fuel/air mix. This could explain your back firing. Change the o2 sensor. Visually check the wirring and connection. If it looks good, I am placing my bet that the o2 swap will correct you problem.
seeker is offline   Reply With Quote
Old 05-09-2010, 10:53 PM   #5 (permalink)
Registered User
Default
that sound like the source of my problem i will have to work on it this week and will let you know if it was. I'm all most positive that's it. Thanks for the help
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
