Go Back   Ford Expedition Forum > Ford Expedition Forum > Transmission & Drive train
Register to remove these ads.
Front Differential/Removed my Drive Shaft
This is a discussion on Front Differential/Removed my Drive Shaft within the Transmission & Drive train forums, part of the Ford Expedition Forum category!
I have had to remove the front drive shaft because we (mechanic) thinks that the front dif is gone bad. ...
Reply
Old 01-26-2012, 09:37 PM   #1 (permalink)
Registered User
Question Front Differential/Removed my Drive Shaft
I have had to remove the front drive shaft because we (mechanic) thinks that the front dif is gone bad. At this point, I can't afford to have this replaced/repaired. What do I need to know or do while the drive shaft is out? Do I need to move my "4wd" knob to any particular setting? Right now its in AWD. Is there anything that I should expect? Is there any type of damages this could cause with the driveshaft out?
I have to admit. I like driving it without that ... sluggish feeling, but I don't know if I am causing additional damage anywhere having the front shaft out and driving it around. Can I leave it like this, and not have the drive shaft reinstalled?
Any info, input, guidance.. .. would be highly appreciated. But I have to admit, I hate this damsel in distress feeling.
Thanks!
DementedChild is offline   Reply With Quote
Old 01-31-2012, 06:21 PM   #2 (permalink)
Registered User
Default
Ok, so maybe I can get some input for my next questions. Front Diff is "going bad".
1) junk yard or rebuilt?
2) any clue as to how much each/either costs so I can determine if I'm getting screwed?
Sure would appreciate it.
Old 01-31-2012, 07:40 PM   #3 (permalink)
sgtowing's Avatar
Super Mod, Supporting Members
Default
If you have a 2hi setting, put it in that.
Sent from my DROID BIONIC using Tapatalk
__________________
2005 Expedition Eddie Bauer 4x4
Volant Cold Air Intake, Borla Exhaust. 18" 2010 F150 King Ranch Wheels
sgtowing is offline   Reply With Quote
Old 02-01-2012, 04:08 PM   #4 (permalink)
Registered User
Default
Unfortunately, the 99 doesn't come with that option.
Old 02-02-2012, 08:06 AM   #5 (permalink)
2000eb's Avatar
Default
just pull the fuse... cant remember which one but it says under fuse cover or in book its been awhile since i did it sorry
2000eb is offline   Reply With Quote
Old 02-02-2012, 08:07 AM   #6 (permalink)
2000eb's Avatar
Default
o if you pull the fuse it will not allow truck to go in 4wd
Old 02-02-2012, 10:44 AM   #7 (permalink)
Default
Fuse in my 01 is under the hood. Im not sure how the awd on a expy works but it may not even move (you're sure its awd and not a4wd right?) my under standing is awd vehicles have a center diff. and diffs like to transfer power to where ever the least resistance is, which would be the front, so i would think that is would just spin the front drive shaft hookup and not transfer much power to the rear. I could be completely wrong, like i said I have no idea how ford went about the awd on expys
masterhacker is offline   Reply With Quote
Old 02-10-2012, 04:23 PM   #8 (permalink)
Registered User
Default
From what I was told, after all this time, was a rod in the transfer case was broken. Don't know if the rod attaches somehow to the front driveshaft, but they replaced this rod in the transfer case and my truck works just fine (so I've been told) I haven't picked it up yet.
Thanks for the info though. I actually plan on pulling the fuse and see if it works for me.
Old 02-29-2012, 11:30 PM   #9 (permalink)
Registered User
Default
No just leave it in awd it won't hurt anything, although I surprised you say its sluggish. You don't have the lag now that you are not turning 4 wheels so it sould be much better and steering in a parking lot should be awesome not having the front shft engaged to give you that bump 4 wheel drive steer in the parking lot. I just thought of some thing, Did you take both sides off or is it just one solid piece, if one solid piece for left and right side you are fine. If it is two half shalfs, take both sides off, or you will jack the front end up even worse. you will be pulling torque from all wheels and missing one which will throw the computer a fit after awhile or damage more internally. Good luck. Tell your mechanic he should know better.
Tha1Mike is offline   Reply With Quote
Old 02-29-2012, 11:38 PM   #10 (permalink)
Registered User
Default
I would go with a junk yard it should be less then a hundred bucks and if it goes out then keep replace it again. You can buy a reman. one for about $6-$9hun w/ $300 core. Maybe Craigslist look for "parting out" good price be about $150- $250 tops. Hope it helps.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
