Gen III transmission leak
GaryH2
SE PA
I have an 07 EL EB 4x4 with about 150k miles and I've discovered an issue with my trans.
It seems the Expy is a jealous type, because it wets the driveway when I don't drive it regularly.
I've found that it leaks about a cup of trans fluid from the electrical connector/plug at about the back 1/3 of the transmission on the passenger side. The connectors from the plug run up to the top of the transfer case. Here's the strange thing: It only seems to happen when the Expy sits for more than a day or two. I found this out because it sat all week while I drove my SHO to the office. Just discovered the wet spot this evening when I went to swap it out for next week.
So my questions are:
Has anyone else experienced this? Is so, what's the part #?
From the ford-trucks.com forums it sounds like its a $450 repair because the trans pan has to be dropped and new seals, but no part name or number was listed in the threads I saw.
Any help is appreciated!
GaryH2
GaryH2
SE PA
It was the bulkhead connector on the right rear of the trans. So if you have a trans leak in a Gen III Expy, check there first. Its above the pan and can make your pan look like its leaking.
Part # 6L2Z7G276AA for about $22. You have to drop the trans pan to access the clip that holds in the connector (and refill the trans afterwards) and that's where the $ are in the repair.
Tocapet
Texas/Colorado
I did that to my 09 today. Replaced the connector $23.10 and 7 quarts of Mercon LV along with a new filter.
ggarriga
Henderson, KY
I hope this is all my issue is. I am going to the dealer this morning to get it checked out.
Thanks!
Garrett
