Big White
Officially, not installed until 2005, but that is what my build sheet says. I read up on it, and it has an additional sensor for turbine speed and logic in the ecm to make more predictive shifts.....That said, I guess the 75 is backwards compatible to the 70, just not the other way around.
SO my question is: Do you think that is what was done? The extra sensor is not used? Where would I find the extra sensor on the transmission, it would be interesting to this geek to see if it is in use....
Anyone else get the 75 in a 2004 that they know about?
