Go Back   Ford Expedition Forum > Ford Expedition Forum > Transmission & Drive train
Register to remove these ads.
Ticking noise
This is a discussion on Ticking noise within the Transmission & Drive train forums, part of the Ford Expedition Forum category!
Im pretty sure i know what is causing it but i just want some opinions but first a little background. ...
Reply
Old 01-30-2007, 02:06 PM   #1 (permalink)
Default Ticking noise
I have always done oil changes myself but last week i just didnt feel like it since i was sick so i took it to Walmart and them do it. I told them to change it with Mobil-1 synthetic since thats what the truck had since day one. So anyway, all was good until 2days which was really cold, I started the truck to go to work and i heard this real faint ticking noise come and go so i sat there until the truck warmed up.
Now normally when that ticking sounds comes and goes its an indication of low oil. I got to work (5 min drive) checked the oil and it was fine. So next thing that came to mind is a lifter might be bad or needs to be tightened. How can i make sure/check lifters.
Also one other possibility could be an exhaust leak from manifold will cause ticking as well and again how do i check this too without having to go to a shop and bend over...
__________________
lakmflx is offline   Reply With Quote
Old 01-30-2007, 05:17 PM   #2 (permalink)
JUST4FUN's Avatar
Admin
Default
umm it dosn't have lifters . lifters are in push rod engines(old
style like 5.0 5.8 v 8s) remember the trytons have 2 cam shafts
on top of each head ran by timeing chains
now the exaust leak look at cylnder 3 and 4and see if the are rotted this is real bad if they use salt to deice the roads .
__________________
2012 F150 Ecoboost crewcab
pearl white
JUST4FUN is offline   Reply With Quote
Old 01-30-2007, 10:24 PM   #3 (permalink)
Default
Yea, your right about the lifter i guess i was thinking about my LS1 trans am when i was typing this...As far as deicing roads i live in florida so they dont use anything like that but it has been hella cold. Only other thing i can think of when Walmart changed the oil maybe they used a different grade that caused the ticking. Im going to change the oil again this weekend and see if that helps any.
__________________
Old 01-30-2007, 11:38 PM   #4 (permalink)
green03's Avatar
Default
I noticed that when I used the Mobil 1 5w30 high-mileage I had a cold startup tick periodically. The regular 5w30 doesn't do it. I have a feeling that the viscosity on the high mileage formula is a thicker when cold so it can resist fuel dilution when it gets up to its 15,000 mileage. The modular motors have hydraulic lash adjusters that are similar to design to a lifter. One side of the cam follower which equates to rocker arm (closest explanation) rests on the the lash adjuster, the other on the valve. The cam presses on a roller that is basically in the middle of the follower.
The lash adjusters can have the same issues that plague a lifter on a pushrod motor......
Matt
__________________
Matt Robinson
Green 03 XLT 5.4 4x4
Powerdyne Supercharger 9lb (kit homemade) (intercooler coming soon)
Built 4R70W With Alto Red Eagle Clutches and Kolene Steels
Baumann Shift Kit
PI Stallion 10.5" Converter With Triple Disc Lockup Clutch
Magnaflow Muffler/Twister Resonator 3" Pipe
Equal-Length Y Pipe and High Flow Cats
NGK Iridium TR6IX Plugs and Granetelli zero ohm boots.
Custom Sniper Tune by Matt Robinson
Factory F150 18" Wheels
green03 is offline   Reply With Quote
Old 01-31-2007, 09:16 AM   #5 (permalink)
Default
Thats what i was thinking when Walmart changed the oil. I looked at the work order but it doesnt state what grade of oil they put in....
Anyways i will change the oil myself over the weekend and just keep an eye on things to see if the ticking noise goes away or starts getting louder..
__________________
Old 01-31-2007, 05:10 PM   #6 (permalink)
JUST4FUN's Avatar
Admin
Default
i use 5w20 and its 0 here no ticking at all 56xxx
__________________
pearl white
Old 02-12-2007, 02:56 PM   #7 (permalink)
Default
Just wanted to give you guys a heads up on the latest. I changed the oil a week and a half ago and since then i havent heard the ticking sound as i did before BUT is hasnt been cold the way it was before when the tick started. Figures lol
__________________
Old 03-27-2007, 11:26 PM   #8 (permalink)
Registered User
Default
Hey folks, I did a google for Ford Technical Service Bulletins and there is one that covers ticking noises. It is TSB number 03164.
The description says
SOME VEHICLES, EQUIPPED WITH THE 4.6L 2V ENGINE, WITH AN ENGINE BUILD DATE PRIOR TO 8/29/03 MAY EXHIBIT AN ENGINE TICK NOISE THAT IS PRESENT AT ALL TEMPERATURES DURING IDLE. 2004 MODELS INCLUDED. *TT
Hope this helps.
__________________
Dave S.
DaveS1955 is offline   Reply With Quote
Old 03-28-2007, 07:46 AM   #9 (permalink)
Default
Thanks for the heads up. I have read that before when i had the ticking noise, all i did was change the oil myself and it went away so my guess is that walmart used a different thickness.
Old 04-17-2007, 05:57 AM   #10 (permalink)
Registered User
Default
Just some food for thought. I too had a ticking noise for the first half of the winter. I too thought it was a temperature issue. Had my oil changed and the tick was still there. When I took my truck to get new shocks and brakes, my mechanic noticed the fuel injector lead was dangling, which was ticking from bouncing back and forth. And ironically it only happened when I started up.
__________________
"you can't fix stupid"
NemesisNJ is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
