bertro
Hi guys.
I had originally posted this on the Gen 2 subforum, when I thought it was a power steering leak, but got no reply, so reposting here now that I've discovered it's actually trans fluid.
It's leaking from one of the metal pipes that go under the front end of the truck to the trans cooling radiator.
Check out the attached pic taken under the truck. The leak comes from the lower pipe at that black plastic bracket. I've put that paper towel upstream of the bracket to make sure that the leak isn't coming from higher up. It's not.
Now my first instinct is to cut off that plastic bracket and see what the heck is going on there (rust hole most likely) and see if I can temporarily patch it with epoxy putty.
Question for you guys: Is that really just a bracket meant to keep the two lines apart or does it actually connect the ends of each line and there's liquid flowing directly through the plastic?
Second question, since those pipes are rusty as hell (gotta love North East winters!) and expensive: couldn't I just cut off those metal lines above the rusty section and replace those metal lines with high pressure hoses instead? That way they'll never rust.
Is that a stupid idea?
Thanks!
Thanks!
