Touch up that rock chip.
designit
oregon
How do you do it?
When do you do it?
Do you thin the paint? do you buff it in after it sets & almost hardened?
Newport News, VA
i'm going to be the test dummy for these MULTIPLE threads that SHOULD'VE been ONE thread...
have you heard of TOUCH UP PAINT?
designit
designit
oregon
come on man... These are all relevant. If not, why wouldn't we just have a detail 'thread' instead of a topic section? Of course I've heard of touch up paint but there's a way to do it and a way not to do it.
I have my methods, but just wondering if anyone else has a cool tip or trick
Besides, I can't afford a car like you have (that's too new to get paint chips) :upyours:
:joke:
Newport News, VA
FYSA...they are working on a detailing section so that should be up and running soon...that has already been requested...
there are plenty of threads/post on here...so if you conduct a search on your questions i'm pretty sure something will come up...
ELVATO
Orlando, FL
It depends on the size of the rock chip. If it's a smaller one (smaller than the entire brush), I take a toothpick and put in paint, little by little to fill in the spot.
For the bigger ones, I suppose you could (carefully) brush it and let it dry. Then, you could try wet sanding it (along with part of the surrounding area), and polishing back to better blend it in.
2000eb
metalic paints must be sprayed even if you just cut a small hole in a piece of paper hold it over and spray. dont use brush for metalics cause they will bunch um etc and in the sunshine you will see a difference especially if it is a decent scratch or big rock chip you repaired
