Need Wiring Schmatics For The Reverse Sensing System
01EXPYEB
Kansas
Does anyone have the wiring schmatics for the reverse sensing system (RSS) for a 2001 Ford Expedition Eddie Bauer with the 5.4 liter engine, AWD. I'm having problems with my RSS. When it is in park I can turn it on but as soon as I put it in reverse it turns off. Owners manuel says you should be able to turn the RSS off and on when it is in reverse. I can not get it to turn on when it is in reverse. I think there may be a short some where in the system and would like to check it. I do have a Haynes manuel with wiring schmatics but it does not show the RSS. Thanks for any help!
01EXPYEB
Kansas
Never mind AvroAero. I was able to get my info from another site. Thanks anyways!
mustangswan
seattle
Most of the time, it is one of the sensors that has gone bad. You could get a new sensor and try swapping it out one at a time to see which one it is, or use datalogger to see which one is not reading the correct distance. There might even be a code stored for the bad sensor.
r98exp1
