Show your Lifted 3rd Gens
JakeEL
What offset did you settle on? And those are 9" wide? looks like a +18mm if so... I had 20x9 +18mm on my old Titan and had a similar look not way outside the fenders more tucked in.
Rim size- 18/9, Bolt Pattern- 6/135, Offset- 18, Backspacing- 5.75"
If I could do it again I would run the 17/8.5 cheaper tires and cheaper rims.
Adieu
SoCal
Whats the UNlifted fender to center of wheel hub measurement, stock? I know mines got some lift, but cant tell how much
bjtj737
Here is my 2008 Eddie Bauer EL. Went with the Rancho Loaded kit because I wanted more travel, not just a spacer kit. It needed all new everything anyways with 120,000 miles. Before and After..
Also got 2 new Exhaust Manifolds done... if you are in Seattle area and need this work done go to Dan Fast in Bellevue. Great exhaust shop.
Super Moderator
Super Moderator
People(Including Ready Lift) keep saying you can fit a 35 with the 3/2 Lift. You cannot if you have the Electric Running Boards. A True 33, Skinnier the better helps. Width of the tire, not just height matters.
Adieu
SoCal
Slamming is an artform... a dubious one, lol
Well that or pure masochism
There must be a special circle of hell somewhere where the tormented souls spend eternity trying to make aftermarket suspensions and aftermarket wheels and new tires sizes all fit together in a way that works
...and perhaps a separate one where theyre then forced to drive the darn things
hsquared360
