acolic
Hi I could use a bit of help.
I was pretty proud of myself changing the front brake lines and decided to change the pads and rotors since I had everything apart.
The left side came out really easy but I am having extreme difficulty with the right side.
First one of the caliper pins is stripped and the torx bit is spinning. I can't see a way of getting the pin out the only thing I can think of doing is cutting the end of the pin off so that the calliper slides off the calliper holder and then try to take the rest the pin out.
The second bizarre issue is I can't get the rotor off. It's seems to have fused to the hub. I tried taking a sledgehammer to it and it will not move off the hub.
Has this ever happened to anyone else?
Any suggestions?
Appreciate the help.
Any suggestions?
