Maleficent
need help with a light issue. I changed out my bulbs to LED. my passenger side, 2nd row light does not work at all. any suggestions?
Did the incandescent bulb work? Or is this something that occurred after the switch?thanks Andy, but I am aware of the polarity of the bulbs. I am leaning towards it being an issue with the contacts on the assemply
Pull the whole housing out of the headliner and check the wires on the back side to make sure the plug is still connected. In addition use a volt meter to check the voltage at the connections in the socket and on the back side.Andy,
yes, the incandescent bulbs worked before the change
the LED bulb works in the other locations, so I know it's not the bulb.
I also tested the wires/connectors
the issue began after the switch.
all other lights work, For this reason I am guessing it's the assembly and the contacts.
thanks for continuing to walk me through
