Upgraded Differential on 2nd Gen?
Vancouver Bob
Vancouver Bob
Vancouver, WA
Thanks!! I've stumbled across the Yukon in my searching and is definitely a possibility. Had hoped to be able to get one of the selectables to work and not ready to throw in the towel just yet :).
Vancouver Bob
Vancouver Bob
Vancouver, WA
Vancouver Bob
Vancouver Bob
Vancouver, WA
pretty sure, all 3.73s were lsd,
& yes, if your original diff was lsd, you can just replace the clutch pack,
can't just do that tho with an original open diff
I have 3.73 gears but was disappointed when I discovered I have an axle code of 16..
Code Gear Ratio (L - limited slip, C - open differential)
15 3.31C
16 3.73C
17 (1997) 3.73C
17 (1998) 3.55C
17 (1999-2002) 3.31C
19 3.55C
H5 3.31L
H6 3.73L
H7 3.31L
H9 3.55L .
Vancouver Bob
Vancouver Bob
Vancouver, WA
op hasn't said what gear ratio they have, if not 3.73, they have to match, front & back
op needs to know what starting with? before what next
expys had 3.73 - .55 -.31 sized 8.8 or 9.75
http://www.fourwheeler.com/how-to/transmission-drivetrain/129-0802-ford-f150-975-axle-build/
Thanks! The 9.75 TrueTrac they show is designed for that C-clip retained solid axle used on the F-150's. Same with the ARB. They say I'd have to have the side gears modified to get it to work.
Vancouver Bob
Vancouver Bob
Vancouver, WA
Thanks, JE070! There are definitely some good LSD options out there.
Anyone know if a limited slip is compatible with Advanctrac? I have read that the Expeditions with Advanctrac all came with open differentials, perhaps to keep the systems from fighting with each other?
Just found this...
According to Ford, a 2004 4X4 with advance trac cannot use a limited slip differential. I deal with lots of snow (Canadian North) and have felt that when stuck in deep snow a standard axle would not provide more than 1 drive wheel in the rear and 1 in front. According to the owners manual when things get tough they recommend turning the advance trac off for better traction in deep snow or mud. For this reason I have factory ordered a 2004 "without" advance trac and "with" limited slip rear axle.
Can personally attest to the comment about better traction in snow/sand with advance-trac off.
Vancouver Bob
Vancouver Bob
Vancouver, WA
So if I believe everything I've read... my only option would be a selectable locker since I can't run an LSD with the Advance-Trac.
First, to show you what I DON't know, I thought it was an 8.8 ! Obviously I am no "wizard" on rear axles.
That just does not "smell" right. I can not believe Ford would have 2 different methods of retaining the axle, one for solid axles and one for IRS. I could be wrong.
Shopping around, some of the places selling 9.75 LSD says they fit F150 (solid axle) AND Expedition (half shafts).
Ha ha... funny about not being a wizard on rear axles! :)
That ARB RD-150 was first touted to fit up to the 2003 Expeditions but as I looked deeper some places said it did and others said it didn't. Called ARB and that's when the guy told me about the differences in how the axles were retained. Without the locking feature in the side gears the half shafts would potentially slide out over time.
Vancouver Bob
Vancouver Bob
Vancouver, WA
Do a quick search.
I can't for the life of me recall which member did it, but there's one on here with a... 2011? and an air locker. I think there's a parts number mentioned as well.
I'm guessing it was the RD-150 because it's designed for the 9.75 34 spline axle. I'll search around some more, thanks!
Vancouver Bob
Vancouver Bob
Vancouver, WA
I don't know but my 05' in 4 low is an unstoppable beast in the snow even without a rear locker.
I hear you... in general I totally agree! Just a few times where I've had opposite corners spinning and I was completely stuck. Once on my driveway! The neighbors helped push me out. And as they were pushing they asked, "Doesn't this have 4 wheel drive?" :). I've had similar challenges in the sand. Even having an LSD would have been nice.
Bretbrat
