Druid
So I really like the look of the 2012-2014 Ford Raptor V-spoke wheels. Not only do they look good, they have a slightly smaller offset (34mm instead of 44mm) and are 17". This means they push the tire out just slightly, helping with clearance for larger tires but without wild changes to the scrub radius and handling. Tires are also somewhat cheaper. They only downside is that they require slight trimming of the rear axle. This amount is really minor, so I thought it'd be nice to provide a pictorial:
Here's a close-up of the wheel being test-fitted to the rear axle. The wheel fits fine, but the center cap won't quite set.
View media item 6452
This is a picture of the rear hub. The pen is pointing to the axle, indicating where it interferes with the cap and the amount to be removed
View media item 6455
This is all that's actually cut off. I used a Harbor Freight portable bandsaw, but a grinder or even a hacksaw would work just as well.
View media item 6454
And here's a view of the axle after surgery. You can still see a bit of the cavity still remaining.View media item 6451
