Blacked-out Blue Oval
Adieu
SoCal
Well that's kick ass!
How are the stock emblems attached?
Two or three self-tapping nut-like squishy thingies (10 or 12 mm socket, I forget) onto nylon nubs extending from the emblem
My $13 emblem came with new nuts
J Ski
3.5plati
VA
With the sinister look of the appearance package on my black Expy, I am thinking about replacing the front and rear blue Ford Ovals with black versions. I found some on EBay, but they seemed way overpriced and I don't think I want to do stickers. Anyone know of other options?
Will be doing black vinyl over the blue on mine tomorrow leaving the chrome “Ford”. It bothers me that the emblems are the only blue things on my white truck
mossback
2017 Limited EL
WA state
Please post a picture of the result. Will you x-acto cut along the script for the chrome areas?
J Ski
3.5plati
VA
Vinyl was a fail. Even with the exacto knife you need a very steady hand and the vinyl doesn’t cover all the blue after your cuts. Ordering black and chrome badges now on amazon
J Ski
3.5plati
VA
Based off of @cibalo post, here are some images of the front emblem removal. I was able to find the theee tabs behind the emblem and remove them without removing the plastic cover under the hood. Tight squeeze but I got it through the grill gaps with just my hands. Here’s a pic of the three tabs and the whole assembly offB9F3E04C-4FB0-4717-87D8-ACC7828F1C1A.jpeg 3BD90C5F-6A09-49FE-AB0B-64E14F6537FE.jpegnext you will need to remove the two nuts on the screw posts pictured here9F866394-DCFD-4D69-9439-ADEC6136BE17.jpegas he stated, twist the posts that you just removed the nuts off of and will look like this
293093B9-39AC-4FBE-8E81-BDCC9B8B57E6.jpeg and emblem will fall right off!
J Ski
3.5plati
VA
Based off of @cibalo post, here are some images of the front emblem removal. I was able to find the theee tabs behind the emblem and remove them without removing the plastic cover under the hood. Tight squeeze but I got it through the grill gaps with just my hands. Here’s a pic of the three tabs and the whole assembly offView attachment 23343 View attachment 23342next you will need to remove the two nuts on the screw posts pictured hereView attachment 23344as he stated, twist the posts that you just removed the nuts off of and will look like this
View attachment 23345 and emblem will fall right off!
@Atlanta Dan
Atlanta Dan
Atlanta
Guys, fyi on an '07 Limited, there is no chrome bezel to come off separately from the grill. There are two speed nuts holding the left and right pins onto the grill itself. I couldn't find any way to turn them so I just pried the emblem off carefully with a flat head screwdriver. It eventually broke the pins with the speed nuts still attached and the emblem came right off. I cleaned off the painted surface of the grill where the emblem mounts and stuck the new one on with the pre-applied 3M tape and it is done. Super easy.
BigRich_Texas
Dallas, Texas
2019 Expedition:
I replaced the stock emblem with a blacked out emblem, but apparently I didn’t have the right one since it was missing the chrome ring/bezel. Couldn’t figure out how to remove it from the stock emblem, but here it is so far.
I’m contemplating just buying a new OEM emblem and blacking it out, myself. Anyone done this?
