another GEM thread....
Rob White
Indiana
What is the friggin' trick to get the plugs with bolts out? bolts are spinning by hand, but that damned plug won't come out....I'm about to get a air chisel and just shred the whole damned thing and replace the fuse box and gem...lol
Bedrck47
Elizebethtown, PA
No trick
Just walk away from it for a short while and regroup
Take your time
Use a mirror and goof flash light so you can get a better view
Remove the cables and then remove both fuse box and Gem.
Why are you replacing the GEM??
Rob White
Rob White
Indiana
No trick
Take your time
not replacing it, just pulling it all out to dry out. previous owner just kept stuffing paper towels and bubble wrap to try to keep it dry, it went wacky on me, so i'm pulling it out and a TON of water ran down my arm, and dripping from the fusebox/gem so gonna put it in some rice and dry it out. then go get a new windshield installed. but for the life of me, the bolts won't come out, and the plug won't even budge...smh...my life...LOL
Rob White
Rob White
Indiana
The bolts don't come out of those two large connectors
Just keep wiggling the connectors
well shit...lol thanks for the info...i thought i saw on a youtube vid they came out...sheesh...lol gonna go mess with it in a bit.
Rob White
Rob White
Indiana
i ended up replacing the fuse box...it was corroded really bad...half the fuses were stuck in...like couldn't pull out with pliers bad...all back together now, but abs/ airbag lights are on, and 4wd switch won't work...smh...
hsquared360
