Headlights
jeff kushner
North of Annapolis
OK Thanks for pointing me in the right direction. My slk has HIDS that come on looking like hidden headlights opening....kind of cool to watch. Guess I need to do some research!
jeff
Z4Mguy
NC
Jeff, please post pictures of your install and results. I'm looking to go the HID route as well.
jeff kushner
North of Annapolis
Will do....I saw your earlier post and was wondering if you'd caught this....glad you did.
The headlight nacelles have locating pins that are tagged together with a plastic band(behind the mounting wall) that should be removed prior to sliding the nacelle out.....be forewarned!
jeff
Z4Mguy
NC
When you say nacelle, you mean the headlight assembly?
Z4Mguy
NC
I'm looking at the Morimoto HID kits, They have both relay kits and CANBUS kits, we have a CANBUS system, right? I'd prefer to use that if possible so as not to have to deal with the extra wiring of the relays.
Adieu
SoCal
Mine needed the relay harness to stop flickering and misfiring.
jeff kushner
North of Annapolis
I received the kit sometime over the weekend and I opened it yesterday to take a look...but that's as far as I got.
Glanced at the install....straightforward.....they suggest 90-120 minutes. My suggestion is that if you find you are anywhere near 90 minutes, don't EVER admit it, TO ANYONE!
It had been a long w/e so maybe I'll get to it this week.
jeff
gixer2000
Retrofit or Bust
Massachusetts
Check out the Diode kit jeff got. They come with Hylux 2A88 canbus ballasts. They can be used on canbus/ non canbus cars and are an excellent ballast.
hsquared360
