G
Guest
Guest
I purchased my '03 in November and I must say that I am not impressed with it at all. $31000 and all I've gotten is a lot of trips to the dealer. It's going back in today for a problem with the xfer case. When I switch from 2wd to A4wd there is a whine and then clunk in the xfer case. And when it's A4WD there is a violent transition from 2wd to 4WD when the wheels slip. I've alreadt had 3 rear axle shaft seals put in on top of it. And body panels keep falling off inside. They're replacing all of them today also. My nieghbor had had problems with his rearend in his '03 EB also. Wish me luck on getting rid of it today. I'm looking at getting an F250 crew cab with as few luxuries as possible. I think Ford made a huge mistake by going to the independant rear suspension. Don't mean to rag on the Expy, but there are some engineering design flaws that need to be corrected before I would consider another. I will still be a Ford man though. Any other problems like this? I see some have had the axle shafts go bad. That's appearing to be very common.
