Carrying cargo on front hitch cargo carrier
Joey Smith
Sunnyvale, CA
I am running low on available cargo weight given my rear axle weight rating (4380lbs). I am currently at 4240lbs (based on CAT scale weighing). My overall payload is 1767lbs and I am at 1287lbs so still have room to add but primarily on the front axle. On the front I am using up 3000lbs of the available 3550lbs (FAWR). I have a 2019 Exp Max XLT 4x4.
I was curious to know if people have used a front hitch cargo carrier to help distribute some of the cargo to the front axle to be able to carry additional items. We carry razor scooters for the kids and I was looking to add portable solar panels and possibly a generator but without some other way to carry cargo, I don’t see how everything is going to fit if I do want to add some additional items (ideally would get a larger truck but that is not currently an option I want to consider)...
Are there safety concerns of adding a front hitch cargo carrier? Straightforward to use and setup? Or more of a bother as it is yet another thing to prepare for trips?
Any input would be greatly appreciated.
JasonH
Houston, TX
What type of trailer are you pulling (bunk, toy)? You'll want to load the trailer axle so that only 10 - 15% of the trailer weight hits your payload. You're supposed to use a WDH to shift some weight from to the front axle from the rear axle. I know this doesn't directly answer your question, but it seems as though you have some margin for additional load. You may be able to shift some weight in the trailer away from the tongue.
J
Joey Smith
Sunnyvale, CA
I have an airstream FC23D (current TT weight is 5560lbs). Tongue weight is 680lbs (based on CAT scale weighings). This is about 12.2%.
I use an Andersen WDH hitch.
TV Only:
Steer Axle: 3140
Drive Axle: 3460
Without WDH engaged my TV weights are
Steer Axle: 2840
Drive Axle: 4440
With WDH (as tight as I believe I can set it based on Andersen’s guidance on how compressed the urethane springs should be)
Steer Axle: 3000
Drive Axle: 4240
My axle limits are:
Front Axle Weight Rating: 3550
Rear Axle Weight Rating: 4380
I am getting some solar panels (~50lbs) thinking about a generator (~50+lbs) and also considering some bikes so was trying to determine whether a front hitch would help or if there were any issues with using them.
I would rather not have to use it as it does mean yet another item to prepare when going on a trip.
Would a different WDH help shift considerably more weight?
Thx.
JasonH
Houston, TX
I reviewed your post history and I recall you were focused on getting everything properly configured, so congrats on your diligence paying off. I use a Husky Centerline 32218. When I adjusted the hitch to move more weight forward, it was able to put 3220 lbs on the front axle, and there's room to go a little higher. So I suspect that yes, another hitch can move more weight forward. One of the benefits of the Andersen is that it's quiet, while the Husky creaks and moans at low speeds. Some people really hate it, but it doesn't bother me. You might have the option of trying a Husky, Blue Ox, or another brand and returning the hitch if it can't do what you need it to do. Of course the setup is fairly intensive, although it should go smoother since you've done it once with the Andersen.
mwl001
Scottsdale AZ
I suspect you can either get more out of your WDH or you need "bars" that transfer more weight... here's what I was able to do with my EAZ Lift and 600lb bars:
F Axle Ht R Axle Ht F Trlr Ht R Trlr Ht F Axle Wt R Axle Wt Tr Axle Wt Tongue Wt Link # (from loose end) GVWR
Unloaded 36 36.5 19.5 19.5 3100 3100 NA NA NA 15300 (I had to exit the vehicle at the scale so unsure if this includes one or two passengers and a full tank).
Ideal 36 35.75 19 20 3260 3640 5140 700 6 3260 (Fully loaded trailer plus WDH).
Kind of jumbled but after calibrating the hitch I get 3260 front and 3640 rear, probably around 700lbs on the hitch. Also less than an inch of squat... here's an easy way to know if you are getting enough/all the weight on your front axle - you want it as close to an unloaded fender height as possible. My fender height is 36" with no trailer and I can get it back to 36" with the WDH. I'd start there. Also make sure your shank allows your trailer to attach very close to level (or slightly lower at the hitch). If that is off, you are doomed to fail in distributing the weight.
I don't know if different hitch types are better or worse at redistributing... I would guess there are just different ways to do it. Mine creaks at low speed too but I like the simplicity and I don't have to be perfectly straight to connect it.
J
Joey Smith
Sunnyvale, CA
Thanks for the tips!
When TV only
[unhitched from trailer but loaded for camping], I am at:
Drive: 3140
Steer: 3460
with TV+TT nonWDH I am at
Drive: 2840
Steer: 4440
With WDH,
Drive: 3000
Steer: 4240
I read this as being able to move 200lbs off of the rear axle and 160lbs went back to the TV front axle.
I was thinking that my expectations should be (for any WDH) that I would not be able to get my front axle weight any higher than 3140 (based on the TV only weight). Is that incorrect?
In your weighings where u were able to get 3220 lbs to the front, do you have the TV only weights and TV+TT with no WDH engaged? Would be curious to know how high the rear weight gets and how much was moved off by the WDH...
Thx!
J
Joey Smith
Sunnyvale, CA
Thanks for the guidance. Also very helpful. Do you have your weights with TV+Trailer without WDH engaged and the weight of your TV only (loaded but unhitched)? Curious to know how much you shifted off the rear axle with the EAZ lift.
I cannot exchange my Andersen now but if that can really help with redistributing the weight, I would think about saving up for another hitch instead of considering a front hitch.
mwl001
Scottsdale AZ
You can definitely add weight to your front axle beyond the unloaded weight. Point of the WDH is to take weight off the rear axle and distribute it to both the trailer and the front axle.
Here’s a before and after when I accidentally didn’t tighten the bars enough. You can see the difference one link can make.
Before
Front 3220
Rear 3900
Trailer 5400
after
Front 3340
Rear 3740
Trailer 5420
by the way even 160lbs makes a difference. I thought I had hooked up correctly but stopped to weigh because the front felt light and the independent rear will definitely tell you when that is true.
J
Joey Smith
Sunnyvale, CA
Before
Front 3220
Rear 3900
Trailer 5400
after
Front 3340
Rear 3740
Trailer 5420
Thanks!
I did try tightening up the Andersen beyond their recommended amount (based on compressed length of those red urethane springs). It did continue to shift weight off the rear but I decided to stay within Andersen’s recommendations...concerned the springs could have issues...
For the EAZ hitch how do u select the bar rating of 600lbs? Does that address a range of possible tongue weights so that 700lbs is addressed?
Also did u consider other hitch options?
Thx again.
mwl001
Scottsdale AZ
EAZ Lift has bars, like a lot of the WDH systems. The bars are rated for a certain amount of bend or weight, mine are rated to distribute 600lbs, so roughly it will put 200lbs on front/rear/trailer. You can swap the bars out if you need to transfer more weight. For now those bars are adequate. I would definitely consider a different system but I bought this TT used and the former owner threw it in for free, so I've just been using as is and no complaints so far. Had to swap out the shank, I have a tall vehicle with the hitch inside the bumper so needed at least 4" of drop.
In your situation, it does sound like you've maxed out the amount your hitch can redistribute, if you're at the max setting. There is a hitch angle setting you could play with as well which might increase the distribution. Again, I'm also assuming your trailer is leveled to your hitch ball because that makes a difference too.
