size of allen wrench for 05 front calipers?
jrk341
Etters
I'm trying to change brakes on our Expedition. What size allen wrench does it take before I go out and buy one? Thanks Jeff
J
jrk341
Etters
seeker,
Thanks for the response. Our 05 is definitely allen head. I determined it has to be 9mm because of all the wrenches I've tried. 9mm is an oddball size so I need to order one to do the brakes. Thanks again. Jeff
ELVATO
Orlando, FL
I think he means a 19mm socket. For some reason, I too remember only have to take 2 larger (19mm?) bolts to take the caliper off.
Unless you're trying to take off the bolts that are under the black dust caps?
I'll check mine tomorrow.
WHOISMOOTOO
Dallas, TX
yup 2 19mm bolts to remove the calipers (use 1/2" drive there on there pretty good)
J
jrk341
Etters
Those 2 bolts remove the caliper and the bracket. You don't need to remove those unless you are changing rotors. Yes, I'm talking about the bolts under the dust caps. I replaced the rotors on the back and the bolts for the caliper bracket took an 18mm socket. Jeff
65comet
Porter, IN
I saw all the posts about the allen size being a 9mm. Sears, Ace hardware, Advance Auto, AutoZone all have 8mm and then skip to 10mm for individual or sets. But NAPA had a 9mm allen 3/8 drive socket in stock. Got home and started the brake job. And the dang bolt on my 2005 is a 7mm. I had just a 7mm allen wrench, so it took a lot of work and time to get them out last night since it was after the stores had closed to go get the socket drive one. I just wanted to post this for anyone else to see. I wonder if my bolts aren't stock is the reason they weren't 9mm.
1955moose
If your 2005 is like my first gen 2000, the size is a t45 plus torx not an Allen socket. I initially got mine off with a regular t45, but it fit loose. The plus t45 is right for mine. Might want to crawl behind it and see.
