Is your Service Engine Soon light on? Has it thrown any fault codes yet?
I don't like to disagree with Stamp11127 because he has helped me out of more then one jam in the past (he has forgotten more then I will ever hope to learn).
But it has been my experience that if the coils had dielectric silicone compound properly put in them, one can drive the Expedition until there is no more gas in the world and they will take forever to dry out. The water is trapped by the Compound, turns to steam and is still trapped because the top of the boots at the plug are the permanently sealed end (heat rises), engine cools, and there is water in the boot again because the steam condenses back into water, trapped again by the Compound, Repeat. Additionally the more the Expedition is driven in this condition the more likely the coil might be damaged and need to be replaced anyway.
So you will have to drop the fuel rail, put your safety goggles on, and blow out each COP with compressed air then make sure they are completely dry inside (I use a HF heat gun). This is of course if you believe there isn't any damage yet. I have gone online and bought a large box of spare COPs and I just replace the one that is causing the problem now instead of messing with drying them as they might be damaged anyway forcing me to drop the fuel rail all over again.
If it hasn't thrown a code yet or caused the Service Engine Soon light to come on, you can probably get away with just drying the COPs. If you have a code or SES, I would find the COP(s) causing it and replace it(them).
Just my experience, YMMV.
