robby830
If the wiring for each door is separate, is it just a coincidence that both front and rear passenger side doors are giving me the same problem?Well if they were working before you replaced the switches that would rule out anything being jumped.
None of the wiring or connectors are in the headliner area they run from the doors to the security module which is located above the fuse box
I will post the wiring diagrams for you before by tomorrow morning
