buildingdoc
Okay.. so here are the conditions.
2004 Expy 4.6. Engine warm either P or any gear. engine surges to 800... sometimes more, then "relaxes" back to about 600 rpm. when it does maintain a smooth idle about 40% of the time I get a humming/fog horn noise.
what I have done. Checked and replaced necessary vac lines. All spark plugs good and seated. fuel filter has about 2k on it. K and N filter cleaned and recharged. IAC changed. MAF clear. no Codes... changed only my bank 2 Catalytic converters.
I am thinking the random idle is due to only one side cats being changed is having the O2 sensors giving different readings to the comp to cause the constant rpm fluctuation.
Any thoughts before I get 4 new O2 sensors and do my Bank 1 cats?
TIA
Matt
TIA
Matt
