Mark Smith
more "bugs" with the EXP obtained recently. It had a crack in the fuel tank that I found when it was recently loaded onto a roll back and started leaking when at an angle. Replaced the tank with a good used one, but when I start putting in gas, it kicks off the handle on the line from the pump after about 1 gallon. Replaced the charcoal canister thinking it was not venting property (used canister from the junk yard). Same problem. Should I be looking for something else that is not venting correctly? Will get a new canister or rebuild the original one with new activated carbon/charcoal... what am I missing??
thanks,Mark
thanks,Mark
