- Joined
- Nov 23, 2014
- Posts
- 5,981
- Reaction score
- 1,336
Oh well you'll get it off. If not just replace broken part. Never ends does it!
Well as some of us old timers have stated time and time again, check fuel pressure at fuel rail. It should be at least 33 minimum. You could have a fuel pump screen that's disintegrated that's struggling to pass fuel through it. Or a weak pump that's on it's last leg. You've replaced all the other culprits. Coils, maf sensor, ran the code checks. Run a fuel test, you can probably borrow the gauge. Exaust leaks will make you lose some power, but as extreme as your problem I would say probably not. I had a 82 mustang gt with a 5.0 liter. When I had an Exaust leak it felt like I was running on 7 not 8 cylinders. But it still ran, didn't die or have your systems. Keep the faith, you've come this far.
