2nd alt 12v hookup
What separate speakers are you using?
Hampton, VA
Subs aren't in the truck right now...subs are PSI platform 3 with upgrades...speakers are 2 sets of massive audio 6.5" components...8" skar audio FSX pro speakers...and massive audio T40 bullet tweeters...
Mr. 10K
Hampton, VA
The amp rack will face towards the front and the box will be back to back with the rack...amps will only be seen be folding down 2nd row seats
Mr. 10K
Temple, Georgia
Watch the charging voltage - a normal regulator will cook an agm battery. I think the max charging voltage is 14.2v, anything above will shorten the life.
Check this link:
http://batteryuniversity.com/learn/article/absorbent_glass_mat_agm
"As with all gelled and sealed units, AGM batteries are sensitive to overcharging. A charge to 2.40V/cell (and higher) is fine; however, the float charge should be reduced to between 2.25 and 2.30V/cell (summer temperatures may require lower voltages). Automotive charging systems for flooded lead acid often have a fixed float voltage setting of 14.40V (2.40V/cell); a direct replacement with a sealed unit could overcharge the battery on a long drive. (See BU-403: Charging Lead Acid.)"
Hampton, VA
Here's an update...all wired up...using small kicker cvr 12s until I paint the box for my 18s
The other pics I took didn't save on phone
Mr. 10K
Habbibie
Is it Christmas yet?
Chicago
10k use wire loom and put a knock out where needed. This is a show car... I don't wanna see all kinda wires all over the place
Hampton, VA
I'm gonna clean it up later...just wanted to get it hooked up and running...I still have to install my be head unit and waiting on new rca splitters for my 4-ch amps...I'm gonna drill holes and run the wire through the back to pretty it up
Mr. 10K
tcwaltz
Niceville, FL
If you wanted true maximum capacity you should have added 4 -6 volt Golf Cart batteries, 2 banks in series, then connected in parallel. I'm a fan of Trojan 2 -105's. That is what I use in my sailboat. If properly vented you'd have no issues with wet batteries, plus you can add water miser caps to return the water that will be evaporated from charging the crap out of them ;).
I had a buddy who worked at a radio station that did some crazy stuff in his Jeep Cherokee back in the late 80's. Massive box with multiple amps. the Two M&M subwoofers. I coudln't take more than about 10 minutes in that thing. I clearly remember the day we watch the crack in his windshield start and move across in a span of about 3 minutes....yeah....the pressure. I'm to old and def for that now. Got a pretty good thump going for my kid in this, but they don't need to suffer from tinnitus for all the stupid crap I did as a kid ;)
hsquared360
