04 expedition 4wd
zach
ni
I have a 04 expedition 5.4 I tried to engage 4 hi no lights on the dash came on but 4 low the light came on and engaged .no lights for 4 awd ether the thing only has 39xxx does any else have this problem thanks
Habbibie
Is it Christmas yet?
Chicago
4wd doesn't have light so when you engage it nothing shows up on your cluster.
4hi does it work? Put it in 4hi and try to make a u turn on dry pavement, do you feel the front wheels gripping making it hard to turn? If it does work then could be something as simple as a burned out bulb in the cluster??
Kim A Larsen
Norway
I can feel it engage in 4 low and the light comes on... but nothing in 4 high and the A4WD. I only hear clicking noise from the relay but does not engage. Can it as simple as the transfercase motor?
Habbibie
Chicago
Most commonly it's the switch itself that has a dirty contact and usually cleaning it resolves this issue. That's just the most common issue I've noticed here from pervious threads
Kim A Larsen
Norway
sorry for late comeback... I fixed 4wd problem... got new 4wd solenoid and 2 new 4wd actuators... now 4 high and automatic works.. before fix only low and 2 wd worked
geovanni
