whitelightning99
Got NO TURN SIGNALS all other lights work,I got to messing around with the blue relay that located under the dash that is for the "signals and 4 way flashers" I pulled the relay out a little bit and with my test light touch pin #2 and #4 together "while key was on" and "the signal switch on to work a signal " and my SIGNALS WILL WORK THAT WAY.
So does that mean for sure the relay is bad ?????
Does that mean my multi function switch/ signal/wiper/high beam switch is working like it should ???????
So what you guys think ?
I took the covering off it and just touch my soldering pen to all connections and tried it still nothing. unless i touch the two pins together like i explained
