Welcome... Your transmission mount isn't connected then. I don't know IF you could get it out with out dropping the cross member or not. The cross member inst hard to remove. the top bolt on the pass side wouldn't come out on mine. A stainless line of some sort was in the way. I think it was an ac line. the bolt comes out far enough to get the the cross member out but the bolt is just stuck in the frame. You will need a 15mm, 18mm box ends and 15mm,18mm sockets. i suggest using a breaker bar to get them off if you have one. Its just easier. Takes some fanangleing because its tight in there but an easy job. Did the bolts rot off or fall out?
