30" Light Bar
Hendu35
Haverhill, MA
I installed a cheap Amazon light bar in the Expy. I mounted it high up in the grill, inside the highest grille slot. Bought their cheap wiring harness as well. Overall cost was around $75.
I had to do a little modification to the top of the grille to mount the bar and drill new holes in the brackets to fit. Works pretty darn well!
I mounted it high because of my experience with the wife's Explorer. On her 08 Explorer I mounted a 30" in the bottom grille between the fog lights. Its very bright but leaves alot of shadow on the road itself if the road isn't perfectly flat. I opted to mount higher to help reduce this "shadow effect".
I'd love to see how its mounted and just general pictures of it!
PrepVet
Weston, WI
I have this 26" sitting in my garage I bought to install on the front of the EL.
I also bought that "bull bar" from ebay that is supposed to be "designed" to fit behind the front plate of the Expedtion. I doubt it, it is from China and I am sure is sold to be "designed for" every car. That said it is actually finished very well. But I don't see any hard mount points behind the front plate to secure it to...
I haven't looked to far into it as it has been cold and snowy out recently, but will look into it.
(please excuse my garage venison freezer)
whitelightning99
Pa
mounted my 20 ebay light bar behind the grill "Said to be an eye sore" member on here, i think it looks much better then the way i had it before hanging over the front bumper with custom mounts i made up
Stepcajun
Oregon
I notched out the grill and mounted to core support, I wish it was a curved light to fit the shape a little betterIMG_20160423_181737477.jpg IMG_20160312_151257255_HDR.jpg
Robert Pina
View attachment 18377 View attachment 18378 View attachment 18379 View attachment 18380 I installed a cheap Amazon light bar in the Expy. I mounted it high up in the grill, inside the highest grille slot. Bought their cheap wiring harness as well. Overall cost was around $75.
I want to do this exact same thing...what mounts did you use and where did you mount them to? Thanks...
ManUpOrShutUp
PA
I've got this project on my to-do list. I've got a cheap'ish 30" curved bar and was planning on putting it in the grille right above or right below the Ford oval. I mock-mounted it on the lower fascia and wasn't pleased with the throw at that height. I suppose I should get on this soon as winter is almost upon us. I don't even like doing oil changes when it gets into the low 20s.
