Just replaced it and still won't come out of park and no brake lights still. What's next?Try This:
Hit the brakes have someone look at the tail lights. No Brake lights equal bad brake switch. There is a metal contact inside the switch that breaks.
Easy fix about 5 - 10 minutes and $20 - $25 part.
- Pull the harness
- Pull the pin cover if there is one
- Pull the pin
- Slide it off
- Don't lose the bushing if there is one
- Reassemble.
Good Luck
No but I did roll it forward to take the pressure off the parking pinI knew the brake light switch would not fix it
did you try jacking up the ass end like I suggested?
