Amateur Antenna through the firewall?
Flight-ER-Doc
Montana
Hi...I've installed a bracket under the hood of my 2015 4x4 Expy Max, for an NMO Mount. Has anyone figured out a good route through the firewall for the cable?
Thanks,
Temple, Georgia
There is a spot behind the driver side valve cover for a clutch master cylinder line. You should be able to see it from the inside if you look up under the dash.
Flight-ER-Doc
Flight-ER-Doc
Montana
Thanks, I'll give it a look. Unfortunately my truck was broken into last week, the (expletive deleted) thief smashed the two drivers-side door windows to get in, and got my briefcase (with keys, laptop and wallet) and radio.
lbv150
Northeast
On my 2016 I came through the passenger side firewall for the main battery power wire for the communications and warning lights.
