Good Day all,
I am needing to replace the tires on my 08 EB standard length 4x4. I found a good deal on some new-take-off Michelin LTX tires with less than ten miles on them. Could probably get into a set for around $600 plus install, if I move quickly. Here's the thing: they are load range 114. From what I understand that's around 2600 lbs per tire. So will these be acceptable? I never tow anything and have no plans to start, but what is on there now are load range E tires, and I am a bit concerned about a tire with a lower rating having more "flex" or "squirm" on the road.
Any Input?
Any Input?
