Cody Dykstra
Hello all, I'm new here.
Although I do in fact own a 2001 Expedition, I am here about something a little different.
My daily driver is a 1986 Bronco. I decided to make it a little more comfortable by swapping in seats from an 07 Ex. What an upgrade! They'e the black and orangish brown two tone leather, with 10 way, memory, and heat/cooling. So far I'e been able to make all but the memory work. They move in every direction, and I have figured out how to build my own module for the climate control. But being that I'm retrofitting these in, and have only limited idea of specifics on these seats, I'm here for a little assistance.
First things first, if anyome has these seats and can test a few things, it would be greatly appreciated. I now need some parameters to set.
First, I need to know just how hot these are supposed to get. If anyone can shoot the outer cushions with an IR thermometer and tell me what they get up to in high and low settings, that'd be great. I'm looking for temperatures when the seat is empty. Basically, fire it up and see how hot the outer cushions get before it shuts down.
Secondly, and this is the harder part, if anyone is bored and can open up a seat and test the voltages for the fan and TED, that will give me a lot better idea of how to achieve desired temperature. I'm hoping to get around the guess and test method. So far it's taking quite awhile.
I want to set these up like factory, I just need to know the numbers.
If anyone can check this stuff, or knows it off hand (or any extra helpful info they want to share) I would love to hear from you!
Also, forums are not my forte;if I posted in the wrong area, I apologize, and although I have done some extensive searching, if there is a thread with info pertaining to this one, I apologize that I did not come across it.
Thanks again
Thanks again
