Towing with a 4.6l?
johnd393
NW Indiana
"4.6l" is too short for a search term.
I'm looking at a 2003 Expedition EB 4.6l RWD.
Why this one? It's available, RWD, affordable, one owner, near enough, and appears to not be abused.
Depending on where I read it the towing capacity is 5000 lbs, or 6050 lbs.
I get it that the 5.4l would be better, I wanna know what the 4.6l can do.
I want to tow a camper.
Prefer something bigger than a popup, with hard sides, needs to sleep 2 tall people, 6'2'' and have a decent sized bathroom/shower.
Anyone have experience towing a camper with a 4.6l?
ApacheJohn
Dothan, Alabama
John, I am from NW Indiana too. Valparaiso/Chesterton area. The 4.6 should be fine for what you are doing. Sounds like a trailer that you are looking for would not overtax the truck. I have a 2001 Ford Expedition 4.6 RWD and I actually will be towing a 7x16 enclosed trailer loaded with our home up to NW Indiana this week. No issues with it towing. I did install Firestone Airbags into my coil springs which helps the ride on mine. I am pretty good at changing the fluids out when needed and taking care of my truck. If you are like me, I don't see an issue.
07xln
Dallas
The 4.6 is a dog. Ive owned two of them and there is no way they can tow even close to their max capacity
I most recently had a 2000 model and I pulled a 6x12 utility trailer with my SxS on it. Total weight was 2700lbs and I had to stand on the gas pedal any time I hit any sort of slight incline just to maintain speed.
You'd be MUCH better off finding a 5.4. Theyre a dime a dozen. You shouldn't have any problem finding a good one
Bedrck47
Elizebethtown, PA
The tow rating for a 2003 4X2 or 4X4 with 4.6 engine is 5000 lbs That info is straight from the owners manual.
The 5.4 4X2 is 8950 lbs. and 4X4 is 8650 lbs
I also have owned Expeditions and towed with the 4.6 and the 5.4 And just my opinion is I will never tow with a 4.6 again. You may be OK on flat ground as long as you are below the rated weight capacity but you will have to stand on it to maintain speed on any steep grades.
Go with the 5.4 you will be glad you did
rjdelp7
2000 XLT
NY
This powertrain is not ideal, but it is a truck. It will get the job done, just may struggle a bit. My Expedition came with a tow package and has 4.6l. People tow with them all the time. A 5.4l only has about 40-50 more hp.
rollinstone
Seattle
I started towing my 3000 lb camping trailer with my 5.0L '97 Explorer. Did OK. Upgraded to my 5.4L '14 Expy, and OMG, what a difference! Only 0.4 liters difference, but I also have a 17 year difference in technology, etc... Go big!
J
johnd393
NW Indiana
Thanks all for your response. The ad is now 25 days old. There may be a reason it's unsold. I've spoke with & texted with the owner and the info seems positive. There is not enough support for towing with the 4.6l for me to make the 60 mile drive to look at it. If it can't tow a decent size camper and tow it well, it has no advantage over my minivan.
1997SCEBFEX
Northwest Panhandle
++ on a 5.4L.
Yes, I too am biased. Hauled this car-hauler and cargo coast-to-coast loaded several times relocating on Navy orders.
I'm retired now, but ole Red (Gen 1 '97) still tows, occasionally, for the hunting camp (lime buggy; trailers loaded with golf carts and wheelers etc.) Let the torque do it's job and watch vital fluid temps.
View media item 1172
View media item 1186
View media item 6295
I’d agree with most of the posters above. The 4.6 is a good motor and will get it done but it has to work for it compared to a 5.4. It’s got a shorter stroke so it’s probably quicker than the 5.4 for daily driving. But towing you’ll be into the gas. Still a good motor IMO and will tow but just be aware of its limitations.
J
johnd393
NW Indiana
OK, I'm still keeping an eye out for a tow vehicle. In used car shopping, I give a lot of weight to price, & condition which seldom lands on the exact specs I might prefer.
Now there's a 06 Expy RWD with a 5.4, 156k & no tow package. I'm finding a 6000lbs spec for max trailer weight but a owners manual give a trailer frontal area max of 36.5 sq ft. I think I can work with the weight limit, but I think that frontal area thing is too restrictive. It's supposed to be rust free, which ain't easy to find around here.
Seller can't see a 7 pin trailer connector. Door tag says H6 axle, I think means 3:73. Can it tow a camper?
From my opening post: I want to tow a camper.
