08’ remote start not working
Plrs X45
Joliet, IL
Hello again everyone. I have watched the recommended videos from everyone (thank you) and have not resolved my issues. The remote start will not start the truck. So far i have reprogrammed the remotes with new batteries as well as replace the truck battery. After each try, the car “beeps” 6 times. I have read what the issue is for 3,4,5 beeps but nothing on what the issue is for 6 beeps? Does anyone know what the issue is what that many “beeps”?
Thanks in advance!
deweysmith
Montreal, QC
Can’t find the exact service manual that I usually use but I found one. The systems are all super similar so this should work.
When trying to activate the remote start, if the horn sounds 6 times, this indicates the remote start system is currently in Valet Mode. To exit Valet Mode, turn the ignition on, depress the brake pedal and press the transmitter button 3 times. The horn will sound once.
