MISTERgadget
TJ, badass build! Sometimes I wish mine were 4x4 just so it could hook on all 4 tires, that would hurt some feelings on the street! We have two very similar builds, great color choice too!
The halo was a 100mm halo. Getting the projector in is very easy. I reccomend using knockoffs of Lightning style housings, as they usually use butyl sealant instead of so-called "permaseal", and it makes for a very easy removal of the lens with a few passes of a heat gun around the edges of the lens. After removing the clips around the edges, heat up the seams, and once you visually see the sealant turning soft from the heat, pull the lens right off.
The Mini H1 7.0 is a tight fit depth-wise, but it can be installed using the threaded shaft and just barely clears the front lens. You have to cutoff part of the ring around where the bulb normally sits to make it easy to tighten everything down, it's very straightforward once everything is apart.
If I were doing it again today, I would use diode dynamics' new HD halos that just came out, they are much brighter, and the best part, made in USA!
Here's a picture I have of the backside that shows more detail:
Can you elaborate on how you fit the mini H1s into the Lightning headlight shell? Also, what size (mm) of XBS 2.0 Switchback Halos did you use?
Thanks and great thread.
