03 no crank...no clicking
Discussion in '2nd Gen - 2003 - 2006' started by jshreve, Dec 8, 2013.
  1. jshreve
    jshreve Active Member
    27
    Dec 8, 2013
    Charleston wv
    Just drove it an shut it off for 20 mins...won't crank....everything lights up but no start...no clicks nothing.... help?
  2. Copper93
    Copper93 Full Access Members
    112
    Jul 27, 2013
    Charlotte, NC
    Check the terminals and make sure they are tight.
  3. metaldrgn
    metaldrgn Full Access Members
    410
    24
    Mar 8, 2011
    somewhere
    Is the security light blinking with the key in the run position?
    Check for power at the F1.101 fuse and make sure the fuse is good.
    Put it in neutral and try and start it. It could be your park/neutral switch. If that doesn't work pull your starter relay and check pin 86 to the negative battery terminal (or any ground) and verify 12v+ to make sure that part of the circuit is good. If that's good you could try swapping a like relay and seeing if it starts. If not check pin 85 to the positive terminal and have someone turn the key to the start position (try to start the car even though it won't because the relay is out) and check for 12v+. If you don't get the 12v+ something is preventing your PCM from closing the internal relay (i.e. a bad PCM or security system isn't cooperating).
  4. jshreve
    27
    Dec 8, 2013
    Charleston wv
    Well I left it sit for about 2 hours an it started right up..haven't had a problem with it since
  5. metaldrgn
    410
    24
    Mar 8, 2011
    somewhere
    I'm glad it worked but I can only imagine you will be weary of it happening again. Could just be the key or lock cylinder not reading the key right. when it wouldn't start, did the security light flash on the instrument panel? If you have more than one key and this happens again, try the other one.
  6. jshreve
    27
    Dec 8, 2013
    Charleston wv
    Did it again ..security. light does not flash ...I can also hear the relay click on the passenger side fuse panel....any ideas ...I rolled it forward an put it back n park and still no start even in neutral
  7. jshreve
    27
    Dec 8, 2013
    Charleston wv
    Security Light stays solid for about 4-5 sec then goes off...any ideae
  8. ExpeditionAndy
    ExpeditionAndy Supporting Member Supporting Member
    59
    1,211
    170
    Aug 31, 2013
    Fort Wayne, Indiana
    Lets start with the basics. What year is your truck?
    In the mean time I remember reading something about this somewhere, let me do some research.
  9. jshreve
    27
    Dec 8, 2013
    Charleston wv
    2003
  10. ExpeditionAndy
    59
    1,211
    170
    Aug 31, 2013
    Fort Wayne, Indiana
    Thanks, sorry I didn't see in the title - Duh!
Share This Page
