05 expy 5.4 tranny issue
Diagenic
Norway
My 05 Expy 5.4 4wd 100000miles started to fail when putting it into drive. Revs up but dont go forward at the matching speed. Got code p0720 and followed by p0126. Have checked the ohm resistance on the output speed sensor to be 439, since that sensor relates to p0720 code. Today i changed tranny fluid and filter to be on the safe side. Cleaned the sensor and put it back, checked the pcm connectors for dirt. Car still goes bad. When i put in drive, no clank sound as it usually does. Goes forward but revs up without the speed to match it. Speedo functions ok. Reverse gear also. O/D light blinks also. Have ordered a new output speed sensor. Dont know if this will fix the problem or not. Anyone who have had similar problems?
Bedrck47
Elizebethtown, PA
Are you certain about code P0126 as that is for Insufficient Coolant Temperature For Stable Operation
D
Diagenic
Norway
Bedrck47: Sorry it was p2106, limp mode. Docraymund: Speedo works fine. It dont engange properly in drive, just reverse.
Bedrck47
Elizebethtown, PA
Some info for you
P2106 - Throttle Actuator Control (TAC) System - Forced Limited Power
Description: The TAC system is in the failure mode effects management (FMEM) mode of forced limited power. This DTC indicates the FMEM action is in effect due to a failure in an electronic throttle control (ETC) related component or module.
Possible Causes:
  • Unplugged motor, circuits shorted to power.
  • TAC motor open, unplugged motor, circuits shorted to power.
  • TAC motor stuck open or closed.
  • Mass air flow (MAF) sensor fault.
  • Throttle position (TP) sensor fault.
  • Module communications network concerns.
  • Manifold absolute pressure (MAP) sensor fault (Vehicles with an EGR system module [ESM]).
  • Output shaft speed (OSS) sensor fault (Crown Victoria, Expedition, Explorer, F-150 4.6L and 5.4L, Grand Marquis, LS, Mountaineer, Mustang 4.6L automatic, Thunderbird, Town Car).
  • Turbine shaft speed (TSS) sensor fault (Crown Victoria, Expedition, Explorer, F-150 4.6L and 5.4L, Grand Marquis, LS, Mountaineer, Mustang 4.6L automatic, Thunderbird, Town Car).
  • Anti-lock brake system (ABS) fault (Crown Victoria, Expedition, Explorer, F-150 4.6L and 5.4L, Grand Marquis, LS, Mountaineer, Mustang 4.6L automatic, Thunderbird, Town Car).
Diagnostic Aids: This DTC is an informational DTC and can be set in combination with a number of other DTCs which are causing the FMEM. Diagnose any accompanying powertrain DTCs first. For Crown Victoria, Expedition, Explorer, F-150 4.6L and 5.4L, Grand Marquis, LS, Mustang 4.6L automatic, Thunderbird, and Town Car with only P2106, repair any ABS DTCs, ABS related DTCs in other modules or vehicle communication concerns using the appropriate section of the Workshop Manual.
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to QE1
Since you have P0720 I would repair that first and see if that solves the problem
Bedrck47
Elizebethtown, PA
P0720 - Output Shaft Speed (OSS) Sensor Circuit
Description: The OSS sensor inputs a signal to the powertrain control module (PCM) based on the speed of the output shaft of the transmission. The PCM compares this signal with the signal of the vehicle speed sensor (VSS) or transfer case speed sensor (TCSS) and determines the correct tire size and axle gear ratio.
Possible Causes:
  • OSS sensor circuit short to GND.
  • OSS sensor circuit short to PWR.
  • OSS sensor circuit open.
  • Damaged OSS sensor.
Diagnostic Aids: Verify the sensor signal output varies with the vehicle speed.
Manual transmission — — GO to TJ1
All others Refer to the Workshop Manual Section 307-01 Automatic Transmission.
Bedrck47
Elizebethtown, PA
P0720 OSS Insufficient input from output shaft speed sensor PCM detected a loss of OSS signal during operation. Harsh shifts, abnormal shift schedule, no torque converter clutch activation. Go To Pinpoint Test E .
D
Diagenic
Norway
bedrck47:do you have a link to pinpoint test E? Measured the OSS to 439 ohms.
