ziad_yamin
Originally posted by itsmarta
I have a 2003 xlt and had roof noises. the noise was a rattling sound. I discovered the roof rack was the cause. The long horizontal piece was loose in the connection to the moveable mounting piece. I shimmed the small opening with a couple of pennys and it ended the problem. The wind from driving would make the piece (shaped like a wing) vibrate in the slot. Heat and cold would make it expand and contract thus causing the intermittent roof rattle.
Hope this helps
Many thanks itsmarta,
This sounds like a reasonable justification.
Did the dealer figure this reason out or did you find it by yourself?
How would I make sure that this is what is causing the rattling sound in my car?
Also, would it be possible if you show (using a skitch) what did you do to fix this.
I appreciate any help and many thanks in advance.
Regards
- Ziad
