Hugh Janus
Did you unbolt the hub?
If not, do that, then try and remove the hub, get the hub to slide out about a 1/4", then try the socket and hammer, see if the cv shaft moves.
This will relieve any binding in the cv joint, or lack of slack in other words.
Isn't this a rear bearing?Did you unbolt the hub?
