07-15 LED Tails, LED Brake and LED Reverse bulb project.
Snomon
Monroe, WA
Today I put on chrome (and not red, smoke, or black) LED tails to compliment the chrome headlights and white body color on my 2015. I also added LED 3rd Brake light and LED reverse bulbs.. Usually I'm not a fan of clear/chrome LED tails, but in this case with a white body, and the chrome accents on this year's model makes it blend in nicely...
Before pic (boo...)
Added driver side first. Note huge resistor it came with. It's like a little brick the size of three 9 volt batteries.
Testing driver side... much better than stock fixture:
Testing LED backup bulb:
Unboxing chrome (more like silver) LED 3rd light
Finished job. Pretty happy how it turned out.
A quick look at the front end to show how the chrome tail LED goes compliments with the front headlamps:
Flexpedition
midwest
Looks great. Why Ford hasn't switched the Expeditions OEM tail lights to LED by now is beyond me. I do like the new front fascias.
montecarlo31
Just a FYI unless things have changed for the '15s you can swap the relay and use LEDs thus keeping th flash rate the same. The replacement relay eliminates that need for resistors and takes all of 1 minute to do with no wiring splicing or extra plugs.
rayt
NY
where does this relay go? is there more information somewhere?
Lostneye
NY
I did this on my 05 so I have no idea if things are in the same place 10 model years newer. However on mine it was under the drivers side dash alongside another relay. There are two types of relays IIRC they are thermal and electronic. You would want to change this to electronic which keeps the same flash rate regardless of load.
Hampton, VA
shouldn't be a problem with just swapping the tails...when you put LED signals in the headlights with the tails is when u might see this as a prob...
montecarlo31
You replace the current relay (which is resistance based) with a time based relay. It's probably all of a 1 minute job once you have the relay.
Any bulb out or significant drop (which LEDs are) will cause a variance in the flash rate. Manufacturers typically use resistance based to alert drivers of a faults.
cheapjeep
Vintondale Pa.
Sorry bud there is no relay. The flasher is built into the body control module on the later Expy's. To eliminate the fast flash bulb out warning you get with led's you have to go to the dealer and have them turn it off with their scanner.No big deal,fleets do it all the time but it will probably cost you $50 or so.
montecarlo31
sorry "bud" you are incorrect but what would I know I've got a late model expediton...crazy right? :favorites37:
rayt
NY
can you tell me where it is? i have a 2011, and my service manual tells me its all controlled by the BCM
