I've owned a GM car new since 2004 and have put 214k on it since then. GM's oil monitoring system uses a lot of data to suggest its oil change time. I drive about 60% hwy and 15% city and 25% mixed normally. I've had my warning kick on as high as 13.5 k and as low as 8.5 k with median about
10.5 k. I use 10w30 non synthetic as recommended. Engine idles fine with no ticks knocks whistles groans etc. and has as much zip as day 1. Its a 3.8L injected normally aspirated V6 with a 4 speed auto plus converter lock up fwd Monte Carlo SS. I've tracked oil usage and mpg since new and still getting 29.7 hwy and 26.3 city. Its living proof how much better oils have become AND how much better drivetrains are made. In my 07 EXP. the change warning comes on like clockwork at 4500 and I basically reset it then and go between 4 to 5k more using 5w20 Mobil one. I will continue this until the M/C floors fenders doors and quarter panels rust out completely and the EXP steel rocker panels and door surround panels rust away clear to the roof. IMO changing oil any sooner than the mfg's recommends is silly and a waste of $ and resourves. My 3 pesos.
