100,000 miles service
Discussion in '3rd Gen - 2007 - 2017' started by Franklie, Jul 8, 2013.
  1. Franklie
    Franklie Well-Known Member
    46
    Nov 25, 2009
    Dallas
    I'm near 100K and never had to do much to my Expy ,07. Just oil, tires , battery, oil & air filters. Knock on wood, been a great truck.
    Guess now's time for: fuel filter, belts, plugs. Anyone see a need for other priority service. i'll check FoMo manual too. The brake pads are still good.
    The updated 07-present brakes are so much better than my '03 Expy.
  2. FisherPete
    FisherPete Full Access Members
    95
    Nov 23, 2012
    Portland, Oregon
    Sounds like you've got the right program. Just make sure the plugs are properly torqued. If you have a mechanic doing the work, make sure he uses a torque wrench and knows the correct settings or he'll be buying you a new head. ;)
  3. Franklie
    46
    Nov 25, 2009
    Dallas
    Change plugs
    Thanks, I have avoided plug change because of breakage reports.
    Youtube and Forum have a few tips. Cross fingers..:headbang::headbang: Why didn't FoMo make the plugs easier to change?
  4. GAIN-MOB
    GAIN-MOB Super Moderator Staff Member Supporting Member
    13,873
    714
    Yorktown, VA
    tranmission fluilds...oil change...CHANGE ALL FLUIDS...radiator fluid...IF ITS A LIQUID...CHANGE IT
  5. bricekin
    bricekin Full Access Members
    243
    20
    Aug 20, 2012
    South Bend, IN
    Sounds like you got the right idea.
    Just did my 100k service about 15k late a couple months ago... had the tranny flushed and filter replaced. Flushed the cooling system. My mechanic said the rear ends are filled with a synthetic fluid and don't typically get changed unless there is signs of premature fluid wear. Same went with the brake fluid and power steering fluids.
    Make sure to check the front axle seals. Mine have been seeping for it looks like awhile and seems to be a fairly common issue based on research. I was going to have that fluid changed but they suggested to see if the leaking was going to get covered under my extended warranty beforehand.
Share This Page
