tinkering
It works similar to a drill chuck but tightens in reverse direction. the jaws inside have teeth on them. It works way better than the old style with the eccentric cam grip, and it is not so bulky for tight spots.
The next 2 pictures simply demonstrate that all of the exhaust manifold studs can be reached by threading the appropriate extension and socket/flex in various ways, from the side and from underneath the vehicle.
Before I purchased the stud remover I tried to extract the studs that were left behind in the head, by 'locking' 2 nuts together on the stud, and backing them out. The nuts slipped even after maximum tightening together. I brazed the end of the stud and nut which worked great.
Here the stud broke when I locked the two nuts together using too much torque. Again I brazed the nut and stud. It worked but this is when I decided to buy the stud remover.
