1998 expedition going into 4x4 problem
Discussion in '1st Gen - 1997 - 2002' started by mikiah, Nov 27, 2012.
  1. mikiah
    mikiah New Member
    Nov 27, 2012
    Ohio
    1998 xlt 5.4 once i try to change it into 4x4 hi, lo, or 4awd it does want to move and if it does it pops very hard and in will barly move, but when i put it back into 2wd, it drives fine. So do you think it is the transfer case? Or is there a motor to replace on the transfer case or something? I nerve had a 4x4 truck/suv so thats what i am thinking, i just got it on trade. Thanks
  2. Thermo
    Thermo technical advisor
    46
    1,407
    57
    Apr 18, 2011
    mikiah, from the sounds of things, you have a bearing that is going on the transfer case. Keep in mind that the front end disengages when in 2 hi, but is engaged when in all other modes. You can try disconnecting the front drive shaft and seeing what you have as it could be the front differential, but odds are, you are looking at a transfer case bearing or a U-joint that is bound up.
  3. mikiah
    mikiah New Member
    Nov 27, 2012
    Ohio
    Thanks man I will try that
Share This Page
